Havent used my car since Wednesday evening, friday I go out and unlock it nothing :surprise:, look at key fob "led working" so unlock manually, stick key in ignition nothing at all. I then check lights stalk I had left the sidelights on for around 2 days!!!!, DOH!!.
Lesson learned, although in my defence that chime isnt the loudest,if only they would turn them off with ignition!!!!.
5w/12v=416mAX6X48h=120Amps or a more simple version 5wX6X48h=1440watts used/12v=120A
Now your battery would have died with in about 12 hours as you use 2.5A for those 6 5w bulbs an hour.
Unless you use LEDs
Must be the season for dead batteries as mine sat in drive with one
But she will roar again once
BTW anyone know how ,any years you get out of the initial battery
Yes I think 20 mins off the battery and the ecu resets itself, it's how I used to get rid of the IMRC solenoid fault p2004 once a week or so before I got an OBD reader.
