1 - 12 of 12 Posts
Has anybody thought about changing there drive pully for a lighter one as i have read they make a big difference up to 20% power and torque
Not saying for a CTR, saying in general terms for any car
Weight reduction is how we are able to increase Horsepower! Each pound of weight removed from the crankshaft is worth approximately 2.7HP and the gains jump even more dramatically with forced induction, nitrous and variable valve timing. Only 15-20% of the gains from our pulleys come from underdriving. The diameter of each of our crank pulleys is reduced up to 20%. We tailor the exact amount of underdrive to each vehicle to maintain factory specified accessory output and performance. We fully maintain all accessory output minimums like air conditioning efficiency, power steering feel, and voltage (minimum allowable voltage 12v) even at idle with everything electrical on in the car. There are no adverse effects from using any of our pulley versions.
Unorthodox Racing
Civinfo's Bulb Supplier
Unorthodox Racing
It's all lobbocks!
Where you would gain any power you would lose an equally proportionate amount of torque and / or drivability too.
Roughly 40 pages of customer reviews from people who have actually owned and used NST Pulley Kits over the past few years...
the COMPREHENSIVE thread on NST (NonStopTuning) Pulleys - 8th Generation Honda Civic Forum
Please take a few minutes to read their first hand, real world, reviews regarding the use of pulley kits on the R18 Civic and K20 Civic Si.
This statement maybe wrong but is from my 15 year experience in the motor trade (5 year as a honda tech) i believe crank pully weight works in
conjunction with the balance of the crank its self and upsetting this balance could result in an unbalanced crank at high rpm which as we all know vtec's like to rev .So in my opinion this mod would cause more damage than good.
Please consider taking a few minutes to read through the 40 pages of customer reviews from people who have been using NST pulleys on the R18 and K20 over the past several years.... You will find no cases of engine failure as a result of NST pulleys...
You will also find lengthy discussion, such as what I will copy and paste for you here....
This one deserves an entire book, but here goes...
Q. Will NST Pulleys lead to premature engine failure?
I cover this topic at least several times a month but I don't mind, I understand that your cars are a very large investment for all of you and I prefer that you be intelligent and informed about all your modifications. So here we go again... Please take a few minutes to read everything I have posted here, as I worked hard on trying to give you a good explanation on the topic...
In the past many engines were externally balanced. There was an external balancer attached to the outside of the engine, on the crank snout, used to balance the engine externally. The crank pulley in such engines would then be attached to this balancer. Removal of this balancer is a bad idea. These balancers were most often used on large (6 to 8) V shaped engines of the domestic muscle car era.
Take a look at any modern (1980s and beyond) Honda, Toyota, Nissan, or other japanese inline 4 and you will find no such balancer. These engines are all internally balanced, and this process has improved even further since the late 1990s. So the topic of a BALANCER does not apply here.
What you will find on many modern engines is a harmonic damper. This is a small rubber band, litterally less than 2mm, less than 1/8th of an inch, thick that is built into the crank pulley. OEM crank pulleys are often called DAMPERS. Try placing an order for a crank pulley at your dealer and your invoice will read damper. This rubber is used to absorb something called NVH, noise/vibration/harshness. Suffice it to say, this rubber is actually not very good at performing its intended purpose after as little as a few thousand miles. What happens to rubber after a couple years of humidity, weather, snow, rain, etc? It often becomes brittle, hard, and crunchy. Can something with these properties actually absorb vibrations very well?
Many many NST customers, including people on your own forums, have reported smoother running engines with NST pulleys. Especially at idle. How is this possible if the rubber is such a vital and super important piece??? Perhaps the rubber is not as important as it is cracked up to be???
Furthermore....
On the topic of the rubber damper, engine vibrations, or possible threats resulting from elimination of this rubber piece...
On a relatively understressed near stock motor with bolt ons or low amounts of boost like what most of the people on this forum probably run, a solid pulley will not have any life threatening consiquences. The factory pulley with a 2mm (less than a 1/8th inch) damper is primarily there for wide band NVH (noise vibration harshness) supression from the engine and driveline. Removing the damper and replacing it with a solid pulley may lead to minor addtional NVH but will not harm the engine. In fact, most people claim their engines seem to run smoother with NST pulleys.
The engineering reasons are that most modern engines have a short, strong crank with, a relatively high natural frequency. The dangerous second harmonic that can cause damage occurs at an rpm that this sort of engine will never see, in the area above 10,000 rpm. Even the stock damper is not tuned for attinuation at this sort of rpm so the argument is somewhat of a moot point.
Now weak engines that are pushing the limit with LOTS of revs, wimpy cranks, super long strokes, lots of boost and dwelling in the upper rpm ranges for long periods of time can benefit from a damper designed to deal with this sort of operation but our engine is not like this, and probably very few people with this motor on this forum push the envelope that hard. How many 2.0 Liter, 500HP, 12,000RPM motors do we have on these forums?
As far as I can tell, our engine has a strong and stiff bottom end that is well built for our intended use. It has an internaly balanced crankshaft which is less like to break due to torsional vibration.
There are a lot of Honda, Toyota, and Nissan guys who use underdrive crank pulleys in road racing series like NASA or SCCA. Road racing is much more punishing on an engine than other motorsports. The engine is subjected to run times lasting roughly 30 minutes with the engine always in the upper ranges of its rpm limit. One race weekend is the equivlent of hundreds of 1/4 mile passes. These guys would not use NST pulleys if they were not reliable.
NST sponsors the first ever wheel to wheel Scion tC NASA Road Race car. The same car is also very competitive in the Grand Am series and has factory backing from Toyota, Scion, and TRD. This car has been using pulleys from NST with great results since day one.
NST has sponsored several drift cars participating in the professional US drift series, Fromula Drift. Several of our cars have also competed in the NOPI Drift series. To make things better, NST products are also used in autocross, time attack, and drag cars. These cars have been using NST pulleys with no issues of any kind for the past few seasons.
We could go on and on...
Is a solid crank pulley harmless to all engines? No it is not. As I said... small, super high reving engines, when modified way past the simple bolt on stages may have problems. These engines reach critcal harmonics, past the 10,000 rpm range, an rpm only reached by certain RACE engines.
A mildly modded inline six will most likely be fine but one subjected to high rpm for long periods of time (90% of its life) with lots of boost will probably suffer. In this case , the stock balancer/damper is probably not adequate either.
Some of the older american V8 engines are externaly balanced and it is critical not to use a solid hub pulley not designed for these applications, or damage to the engine could result. You will not find solid NST pulleys on our website for such engines.
Our engines and most around here do not fall into the above catagories. Rest assured that your engines will not blow up and die or have a reduced life in street and even racing use with these parts.
I would bet that every "expert" that tells you otherwise has little personal, practical, real world experience with the subject; as it applies in your case.
Again, I understand that your cars are a very large investment and that you depend on them as your daily means of transportation, so I do not take your questions personally. But please remember... No NST product is designed to cause you any harm or grief. We are not in business to sell junk. PERIOD.
I can share the following real world info with you based on my personal experiences during my past decade of drag racing, road racing, and professional drifting...
Dan Gardner's NASA road racing Scion tC, backed by Scion, Toyota Racing Development, and NST has never had any bearing issues while using a full array of NST products over the past few years...
NonStopTuning's turbocharged S13 drift car competed for several seasons in the Formula Drift Pro-AM and other drift series and never had any bearing problems...
Tommy Suell's Formula Drift AE86 drift car was consistently ran at redline for several seasons and was putting down twice as much power as it did when the motor was in stock trim, and it never had any bearing problems...
NonStopTuning's custom turbocharged 4AGE 2009 D1GP USA drift car ran the entire season on the same engine, using the entire catalog of NST products for the 4AG, and never had any engine problems of any kind...
Not all aluminum pulleys are created the same, and no other pulley is an NST pulley.
How the hell can anybody be bothered to muck about like this with what at the end of the day is simply a nice quick family saloon, not a supercar.
Leave it alone and enjoy it - most mods are an absolute total waste of time for road use, and they don't half drain your bank balance!
And they generally devalue your car rather than enhance it's value - would you honestly buy a car extensively modified by an amateur?
I wouldn't touch one with yours!!
1 - 12 of 12 Posts
