Silicone spray works a treat.
pull belt all the way out spray belt at the top either side. Let it retract a few times should work unless theres a component fault.
Clean the belt and the metal runners at the top. Use a cotton bud or a flat head screwdriver with a bit of cottton cloth to get into the metal bit.
Failing that a bit of the dashboard shine sponge on the top of the belt on the side that faces out towards the steering (NOT THE INSIDE OR ITLL END UP ON YOUR CLOTHES) and it should slicken up nicely.
Try cleaning the belt and runners with a mild fairy liquid solution first before trying the dash shine sponge.
got a 1.4 2011 plate s type pleased with the car but lately felt its not responding to throttle after 2nd gear very sluggish to respond is there any thing i need to check gets abit embarrasing when smaller cars wizz past:(
So I know this is fairly common and yes I've read the other threads
so I want to ask, I cant for the life of me find a drain hole in the fuel filler area on my 2.2 diesel - is there one for my car please?
Hi
Just a quick question - the OH was out in the car last night and reported that the heater wasn't working. Tried it this morning and it seemed fine - for about 2 minutes - and then it shut itself off.
I noticed that the motor sounded a little noisy, but other than that it seemed fine - I was...
This has been for sometime now and it's getting increasingly frustrating I had a leak in the boot where it runs around the boot the rubber part.
It's also on the rear strut tops?? Where are the common problems at because I can't see anything on the net mk8 civic... Also noticed slight water...
Hello,
Recently my passengers side heated Wing mirror has stopped working, although drivers side is fine.
The electric mirrors move fine on both sides, just seems to be the heated element on that 1 side.
Any advice??
