1 - 12 of 12 Posts
Hi guys,
So i have an FN2 Civic Type R currently without any fog lights on the front. I am looking to put them in, but what i would like is to install them as DRL's (so naturally they come on with ignition and engine start and without the lights on.) (NB: are DRL's supposed to turn themselves off when you switch main beam lights on?) If so then i would also like to connect them to the fog light switch so that when the fog lights are required they then come on with the rear fog.
I hope this is something that can be done, if anyone has managed to work out how to do so i would really love to hear from you!!!
Also if anyone has drawn up a step by step that would be brilliant!
Thank you in advance!!
Sure, there are several How To's e.g. [HOW-TO] Install fog lights - Page 4 - Civinfo
If you fit fog lights, then you'll need to ensure they pass the MOT.
Thank you for this information. It is going to be really helpful Thank you so much!
Does this how to guide only show how to install them as fog lights? If so, is there any way (is it even possible) to connect them (as well as fog lights) to make them DRL's?
Thank you
Marty says BWAAAHHH!!!
I use my fogs as DRLs and coming home lights
are fogs ok to use as DRL's?
I have sides as DRL's at the moment. OP - I retro fitted fogs so happy to help if I can....
When you say sides, (sorry if this sounds naive) what do you mean? Do you have pictures?
No i must have missed that. Thank you i will look now.
That is the module I have. X5252X specifically made a module for fogs after my request for it.
1 - 12 of 12 Posts
