41 - 47 of 47 Posts
Nice one @piasek, I had some of the cheaper ones and they lasted approx 9-12 months. Can't find the supplier of the ones I have that have lasted for 3-4 years on the FRV which is a shame.
FYI, I have had several MOT's with switch backs fitted with no issues, you should be OK because you have the relay fitted.
Does anybody have any experience with those? b2b.einparts.eu/gb/1793
Are there any good and how complicated is wiring?
Job done. It was very bright when I made a video but in real they are very bright. I hope that they will last at least a year. Just in case I will pull the fuse out before going for a MOT.
Does it still work? How did you connect it, can you take some pictures or make a diagram...
Was it the Grayfox way or the Bones126...or a bit of both?
They still working fine. I’ve connected them using one of the cheap drl modules.
One
One module per bulb or one for both? Where did you connect the yellow wire?
One module for both bulbs. Yellow wire connected to side lights. So when you switch on the lights drl switch off.
41 - 47 of 47 Posts
