That's the one.Is it "Daylight Running Lights" ?
Hope that helps
Ray
... and only lights up if they fail. BTW Uk Civics don't even have the bulb.That's the one.
Only used on European Civics.
Sent from my X10i using Tapatalk
Adaptive Front-Lighting System, normally anywayThere is also an AFS light... Does anyone know what that is?
Ahhh, makes senseAdaptive Front-Lighting System, normally anyway
I assume the civ follows suit, it's when theres a fault with auto-level headlights
Cheaper for Honda to mass produce one dashboard and just not use a part of it, than to manufacture two different models.Errrm well I thought so .............BUT why put it there and then not bother with installing them. Question is can the car be programmed to use this feature without installing aftermarket DRL's.
This was simple on my passat Just use the VAG software and done
I would imagine the DRL's on European Civics (which I believe just makes the headlights come on when you start the engine) is controlled by the MICU. Short of getting an MICU from a European Civic, I doubt it would be possible.Errrm well I thought so .............BUT why put it there and then not bother with installing them. Question is can the car be programmed to use this feature without installing aftermarket DRL's.
Exactly this.Cheaper for Honda to mass produce one dashboard and just not use a part of it, than to manufacture two different models.
I thought all MY09 Civics had tyre pressure monitoring as standard?It also has a TPMS(Tire Pressure Monitoring System) light spot.
and a special one called CMBS(Collision Mitigation Brake System) light spot
Don't know about the UK version but mine has DWSWould that light not just be to notify you of a problem with the system anyway?
It doesn't.
Why does it surprise you that you've got a tyre pressure monitoring light then?
Ah OK. The context it was in it sounded like you were saying the light isn't being used even though you have the TPM system.It doesn't.
I know it is easy for a company to make one gauge cluster.
