My civic is doing a noise when I turn a low speeds , I recently replace the strut mounts but still noisy.
I been checking the drop links when a press the rubber bit seems really soft? Can be the drop links?
Automotive tire Motor vehicle Automotive exterior Bumper Automotive lighting
the rubber is there to protect the ball joint inside, if it is split then they need replacing
if the links are shot they will clunk and show some movement
If it says “klonk klonk klonk” when you turn at full steering lock, it could be the outer CV joint.
Ex-Pat Geordie! and Moderator
I'd try the Anti Roll Bar bushes too, an easy cheap fix.
