1 - 1 of 1 Posts
If anybody need advice on how to build this project let me know. Firstly I used tap fuse into number 27 fuse( constant 12v), because tap for the fuse cannot fit into fuse 34 ( first turning key 12v), But its ok as lon I dont forget to turn the dvd off :) After that remove the back cover of the seats (on the driver side I brake 2 clips that holds up the side seat cover but super glue did the trick) Run the wires thru headrest wholes. The with zip ties tight the cablex under the armrest ( be carefull the wires not to touch any handbrake cables) Cut the whole for the switches and thats it, Get a groud source from the bolts around the handbrake. I left space around th swirches for 2 led diodes, that will light up, when dvd is opereting (not t ofrget to turn them off, constant power). I can take photo If needed, this is only two that I got today.
Sorry for my bad english, I will try my best
1 - 1 of 1 Posts
