1 - 18 of 18 Posts
· Premium Member
hi all after getting a bargain of rob for my springs do ineed to buy the front drop links only to do the springs thanks
· Premium Member
The drop links will need replacing and will set you back about £25 also camber bolts around £25 and then a decent garage to adjust them. Camber bolts are essential or you'll ruin your tyres
Reactions: smig64
· Premium Member
Discussion Starter · #3 ·
just ordered the camber bolts was gona order one of those camber gauges that stick on your discs would that not do the trick with the camber settings
· Premium Member
Mine were in good condition and came off easily, but they'd never have gone back on. It's definitely worth replacing them. Fit the springs yourself and you'll save a fortune but get a decent garage to finish the job.
· Premium Member
Discussion Starter · #7 ·
thanks guys will be fitting them myself the camber gauge i seen on here somewhere it has a magnetic end you put onto disk then adjust the camber bolt to correct setting they only 20 quid worth it i suppose
· Premium Member
Is this right? if you fit the Eibach lowering springs, you have to fit drop links and camber bolts and get them set up. I thought it was a simple swap.
Mind you, my son fitted Tein springs on his ep3 type r and it goes through front tyres in less than 10k miles!
· Premium Member
Discussion Starter · #9 ·
think the drop links are more of a why you there do them as sometimes you need to cut off the drop link as the threads and bolt sieze a bit its just if you struggling and you break one your stuck as for the camber bolts i was the same aint heard of these before i bought the civic just used to go n get tracking done afterwards i will get the drop links just incase tho
· Premium Member
you dont need the camber bolts but if you do fit them it allows the tracking to be set to run some negative camber improving cornering ability even more. its not a must have but as you need to get the tracking done anyway and the camber bolt replaces one of the bolts you will have taken out anyway then why not do it?
· Premium Member
Discussion Starter · #11 ·
agree buddy i am replacing them hopefully fit them this weekend just looking for a new set of allys at the same time
· Premium Member
Discussion Starter · #12 ·
just noticed you one of those over the water types lol
· Premium Member
Discussion Starter · #14 ·
your from sunderland im originally from newcastle lol
· Premium Member
Discussion Starter · #16 ·
no mate lived up here in scotland since 1998 thinking of moving back soon tho
· Premium Member
Fair point, when I order my springs, i`ll order the camber bolts, thanks. :)
1 - 18 of 18 Posts
