The Ginga Ninga
Has any body else had this?
Since I removed the door trim to fit the puddle lights, if I use the one touch to close either fron window, it closes till it gets to nearly closed then opens itself about an inch. The only way I can fully close the window is to just tap the switch up until fully closed. I thought it was the door trim on too tight, but I tried it today with the door panel off & it Still did it
Aaarrrggghh!
Help!
