Hi, My accord deisel estate engine is cutting out whilst driving, this has only started since my last service. any ideas on how to resolve the problem. Thanks
Sorry to hear that you have a problem.
What work was completed during the last service?
When were the filters last changed, air/oil/fuel?
Were OEM filters used?
Do you have any warning lights?
Have you check for any error codes?
Bye bye Honda...
What happens when it cuts out... Does it simply restart again and off you go?
I'd be tempted to ask whoever serviced it to explain what they've done!
Hi Jon All filters were changed with original equipment, the motor takes several attempts to re start. I do get a flashing glow plug light?
Bye bye Honda...
You need to use an obd2 reader.
Flashing glowplug light often indicates a fuel rail pressure problem, often caused by a dodgy fuel filter. I'd really want to check that the proper filter was really fitted (Bosch if pre-facelift, Denso if facelift).
