1 - 12 of 12 Posts
Well its a good job i plan on ripping the dash apart soon because i got in the car today and the instrument panel for the stereo/ac etc wouldnt come on, neither would the stereo turn on. Now ive tried changing the fuse 35?, correct me if im wrong.
Any ideas?
Regards, Olly
Bye bye Honda...
Unfortunately my manual doesn't cover the CTR. But this is the result for the 1.8...
DTC Troubleshooting: U0155 (126)
DTC U0155: F-CAN Malfunction (Gauge Control Module-ECM)
NOTE: Before you troubleshoot, record all freeze data and any on-board snapshot, and review the general troubleshooting information.
1. Turn the ignition switch ON (II).
2. Clear the DTC with the HDS.
3. Check for Temporary DTCs or DTCs with the HDS.
Is DTC U0155 indicated?
YES - Go to 4.
NO - Intermittent failure, system is OK at this time. Check for poor connections or loose terminals at the gauge control module (tach) and the ECM.n
4. Check for body electrical DTCs in the DTCs MENU with the HDS.
Is DTC B1168, B1169, and/or B1178 indicated?
YES - Go to 5.
NO - Do the gauge control module (tach) input test.n
5. Turn the ignition switch OFF.
6. Jump the SCS line with the HDS.
7. Remove the gauge control module (tach).
8. Disconnect the gauge control module (tach) 36P connector.
9. Disconnect ECM connector A (44P).
10. Connect gauge control module (tach) 36P connector terminal No. 1 to body ground with a jumper wire.
Open the figure
11. Check for continuity between ECM connector terminal A36 and body ground.
Open the figure
Is there continuity?
YES - Go to 12.
NO - Repair open in the wire between the ECM (A36) and the gauge control module (tach), then go to 14.
12. Connect gauge control module (tach) 36P connector terminal No. 19 to body ground with a jumper wire.
Open the figure
13. Check for continuity between ECM connector terminal A37 and body ground.
Open the figure
YES - Substitute a known-good gauge control module (tach), then go to 14 and recheck. If DTC U0155 is not indicated, replace the original gauge control module (tach), then go to 14.
NO - Repair open in the wire between the ECM (A37) and the gauge control module (tach), then go to 14.
14. Reconnect all connectors and the battery.
15. Turn the ignition switch ON (II).
16. Reset the ECM with the HDS.
17. Do the ECM idle learn procedure.
18. Check for Temporary DTCs or DTCs with the HDS.
Are any Temporary DTCs or DTCs indicated?
YES - If DTC U0155 is indicated, check for poor connections or loose terminals at the gauge control module (tach) and the ECM, then go to 1. If any other Temporary DTCs or DTCs are indicated, go to the indicated DTC's troubleshooting.
NO - Troubleshooting is complete.n
All the rest of the gauge clusters work so my thinking it is a broken connection in the Clock/radio screen but i dont imagine that would explain why the radio wont turn on, loose connection? A previous owner has definately had it all apart before.
Bye bye Honda...
Does sound like a potential nightmare! Good luck...
I've read some people have had broken stereos if the screen and lighter are wired to that could that be the problem....
1 - 12 of 12 Posts
