That sounds like something loose resonating. possibly the exhaust manifold heatshield or air filter housing?Hi guys,
I've just started to notice a strange engine noise when reving when idle. Can anyone diagnose?
Sound
I can hear a tapping noise just after the engine starts. I don't know what it is, but maybe one of the hydraulic tappets or something driven by the aux belt? Is it worse hot or cold?
The sound stays when its warm. in fact it gets worse off when engine is warm, can hear the engine tiring out when turning the engine off (so thoguht it was the chain).I can hear a tapping noise just after the engine starts. I don't know what it is, but maybe one of the hydraulic tappets or something driven by the aux belt? Is it worse hot or cold?
Best thing is to remove the aux belt and see if the noise goes away... if it does it's easier to investigate with the belt still off.
Thanks for the feedback,You can't easily take off the i-CTDi cam cover... the injectors all need to come out first! In fact, lots of other things also have to come off, which all makes it a pretty big job.
If you can smell exhaust then it could be a cracked manifold, or it could be a leaking injector gasket... which might just make the sound you have recorded. A leaking injector gasket can be confirmed by either feeling the escaping gases by putting your hand above the injector with the engine running (or spray WD40 round a suspected injector and look for any bubbling) or the leak may be obvious by the build-up of soot.
sounds to me like youve got a unofficial/blueprint air filterHi guys,
Sound
You're probably correct. I recently had a full service. Thank you.sounds to me like youve got a unofficial/blueprint air filter
