i have a engine warning light come on, on my 2007 civic type 2 2.2ctdi, i took it to my local garage today who let me use there kit, it came up with error on sensor for intake manifold , i reset it before i wrote down the exact fault codes, is there anything in particular that goes in that area i could replace > it drives fine , no issues at all, just annoying warning light comes on and goes off everynow and then
thanks
Oldboy-racer
Sounds like it could be a dogdy connection. Maybe check the connectors for corrosion?
Sent from my SM-N910F using Tapatalk
Bye bye Honda...
IMRC errors are common, gives a P2004, P2006 or P2008.
Boost high or low conditions are picked up by a MAP sensor, but I can't remember the codes.
