· Premium Member
Hi Guys
Have a 1.4 Type S (RHD) civic here. B/Middle pipe has split right where it meets the centre box.
Ordered a replacement from local motorfactors off the part number 18220SMGG11 but exhaust that came in whilst looking the same didn't fit, they ordered a second one and again same problem.
The issue is at the flange towards CAT end, in my car the middle pipe connects onto the cat convertor, but in the schematics from the factors its like its 2 cat converters, or a different pipe and then the cat. Motorfactors are scratching heads and can't figure it out
I've attached a pic below of of the difference with both exhausts lined up, everything else is matching just the flange angles
Anyone seen similar before or got a different part number I might be able to work off?
· Administrator
MY22 Jazz EX Hybrid
· Premium Member
Discussion Starter · #3 ·
I actually used this for the second one they got (spurious bosol exhaust 283799) but its same
Car is a 2011 model and 3 doors if that makes a difference
· Premium Member
Discussion Starter · #5 ·
Just to add, can anyone confirm that these are single and not dual cat converters?
Looking at the image below and from being under it it just looks like I've a single cat, then only the exhaust manifold, but red circle below is where the problem area is
Has anyone else done a DIY replacement and ran into the same issue?
