Hello everyone!
I just fitted my Milltek non res yesterday with my friend.
Everything went on fine, and i only broke one bolt on the rear of the OEM backbox, which i was quite please about (i expected the bolts on the CAT to be a nightmare).
Anyhow fitted fine, sounds great etc
however... the back right pipe seems to be rattling against the meal inside the triangle, but only when the car is stationary / under 4 mph.
Is there any tricks or any material or anything i can do to stop it from rattling... obviously quite annoying!
Cheers guys
COTM Feb 2012
Im pretty sure ABP cut away some of the triangle inside to fit this...
COTM Feb 2012
The grommit is definately not loose,
and that would make sense but i dont really have the tools to do that (cut away the metla bit)
Is it metal inside? not plastic?
Do you have a garage near that can cut? Can only be a 10 minute job
Reactions: FrankstaH
Had mine fitted by ABP, and I believe they cut some of the rear plastics away to prevent it catching.
