Hi does anyone know how to remove the silver exhaust triangle tips? To clean and in my case chop down a bit as it's catching the rear tailpipe
Thanks in advance
Alright Mate, I removed on my Type R as wanted to re paint them, anyway go underneath rear bumper , spray some wd40 over the rear nuts that hold the triangles on place and leave for a while, as all the road salt etc makes them rust on a bit solid, anyway say nx day you should be able to get a 10mm socket on them and hopefully free up, thinks there's just 2 each side then they slide over the tailpipes at an angle and you can get them off, then you can cut , trim , spray do what ya please mate ! Hope this helps !
Cheers for the reply pal I'll try that first thing.. had a stainless silencer put back on my type r as it was too loud but ever since they've done that it's rattling against the triangle.. I might polish them up when there off too
No worries mate, I had custom race exhaust fitted to mine , so I needed to remove the rear of the triangles , once they were off the car I just got the angle grinder and removed that surround that comes out of the rear of the triangle , it's there to direct the gasses out the rear, anyway I needed more room so I removed it , I actually sprayed mine first with BBQ paint but this lasted only days , app I have a lot of heat out back and the odd flame , hence they were all bubbled and cracked looked like they'd been on fire LOL ,got them powder coated and been fine since Mate !
Thanks in advance
As OsakaJ said it is 2 bolts either side which are accessed from behind the bumper. The picture below gives you some idea how they are fixed.
Good luck mate!:smile3:
