1 - 20 of 30 Posts
Ageing Petrol Head!
Any idea on the gains I could expect from the fitting of a Flashpro,Inlet & Exhaust Manifolds & Induction Kit.....Rolling Road set up too........??? Thanks in advance....:)
COTM Feb 2012
230-240 depending on your stock car imo
COTM Feb 2012
That seems to be the norm for those mods, without the engine manifold (I think!!!) Mr JP had 225bhp with those mods. He DIDNT have flashpro and also had a standard "R" under 200bhp too..
Pretty close I reckon..
Civinfo's Bulb Supplier
Not naming any names but there are some very optimistic dyno's out there, critically it depends on what you are putting out standard, but with the aforementioned mods I would say you should expect to see 225-230BHP on an "R" making factory quoted power.
is that an informed knowledgable opinion or a best guess?
this is a copy paste from Dawid s signature and he claims 250 bhp
if you do the calculations and find out horse/money value .......you realise that its a huge task and don't think worth it IMO.
'''''''''''''''''''''''''Type R GT -5207 Nighthawk Black - Current Power : 250BHP
Hondata FlashPro ECU + GruppeM RAM Air System + (Injen CAI + Hydroshield) + RRC JDM Intake Manifold + Hondata Heatshield Gasket + TODA Exhaust Manifold + Milltek Cat-Back Exhaust + Clutchmasters FX400 Clutch *6 Puck Disc* + Clutchmasters Aluminium Flywheel + Greddy Spark Plugs + TODA High Power Camshafts Spec E + TODA 0,3mm High Power Head Gasket + TODA High Power Valve Springs + TODA Timing Chain Tensioner + RC 440cc Injectors *Powered by : V-Power 100 Octane Fuel*'''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''
Ageing Petrol Head!
My thoughts exactly....different dyno's rarely give the same results, with the amount of variables and human input etc but I think I get the picture....CPL will be doing the work so should be reliable and as accurate as possible.......Thanks....:)
CPL are one of the good ones, I've been in there workshop and dyno room and seen they do proper runs etc with proper IT's and no fudging at all.
Be sure to get your figures posted up here as and when please :D
hub dynos are the most accurate but there are parameters like ambient temperature or in wich gear or how many seconds do the run........... and you can have different numbers in the same dyno and the same car .
Ageing Petrol Head!
Discussion Starter #12
As for "money for results" my friend you are quite right.....having spent sums of money tuning bikes I know only too well things never add up.....but being an old petrol head what can I do.....;)
Ageing Petrol Head!
you are right the variables are huge, but I feel if you get things fitted and set up by a well known, reputable outfit then you stand a chance of getting the most reliable use from any modifications
Dynos are just tuning tools. Bhp figures are just calculated guesses and pub talk. It's how it drives that is important but regardless of who you use 230 should be attainable.
Alternatively px the FN2 and get a ab S2000 and get te best engine output ever made for a stock 2 litre! ;)
Bloody iPhones!
P1259 ODB-II
Rolling roads are great fun ... But you'll need to use the same one each time you test a mod. That way you can setup the same conditions and actually see a change. I know locally the rolling roads read differently with the same car and approx conditions. In one case 25bhp gain over the average readings
Ageing Petrol Head!
Discussion Starter #19
I would agree that it's important to use the same dyno/specialist.....I did a little homework and although I have some locally decided to use one such specialist over 3 hrs drive away. Important, oh yes:p
got mine done other day and she is putting out 230 but that was after a lot of runs
so might be a bit faster if it was not that warm hopefully ;)
1 - 20 of 30 Posts
