I hate faded plastic trim, after living with it on my 8G I replaced the plastic arches on my 9g with painted ones shortly after getting it and am really glad I did, (see an earlier post for a picture if interested)
The plastic panels below the windscreen on the 9G have done the same thing so I'm trying an experiment and am prepared to buy new ones if it goes horribly wrong.
On the 8G arches I tried all sorts of chemicals with no permanent result, the best I could get them was to use a heat gun and kitchen scouring pad to remove the residue which made things bearable - almost.
I wondered if some of the problem is residue left from cleaning products containing wax and other crud that sticks to the grained finish so have tried applying Auto Finesse Revive using an old kitchen scourer in circular motions then wiping the residue off.
Although it is early days it seems to have made a difference, usually the dark appearance only lasts a few days but looking at the muck that came off I would say it's certainly done something, you can see the original colour at the edge of the washer jet hump, sadly I didn't take a picture before I started, you can see what came off on the old towel I used to wipe it with afterwards.
I will be giving it another going over over the holiday and will post an update.
