Some folks have been asking how to swap out the clutch damper, so I figured I'd outline what I did.
Disconnect both battery terminals, remove the battery restraining strap, remove the battery and plastic battery box
Unbolt the battery tray, 6 bolts.
Loosen the hose fittings to the back of the damper #33 and both ends of the flexi hose #24. Use flare spanners on hose fittings (10mm and 12mm need for the lines).
Remove OEM parts damper #33 with 2 bolts #41, remove hose jumper #32.
Remove the flexi hose #24 and it's two clips #36.
Connect Freaky's new braided hose to the solid lines #25 and #29, it will only fit one way
Add grommets/cable ties to the new hose where it runs through #34 and #28.
Carefully nip up the new hose connections as they could compress the hard OEM lines if over tightened.
I then pressure bled the clutch with an Eezibleed kit, forcing fluid through from the clutch master cylinder. It's an 8mm flare spanner for the bleed nipple.
Test the clutch pedal with the engine off, you should now feel the diaphragm working
Test the clutch with the engine on, carefully.
The biting point on my pedal rose considerably and needed adjusting back down.
Once you start the job it then makes more sense, honest
