There was 1 negative...faster pickup means more clutch slip!
Sent from my LG-D855 using Tapatalk
...only if your clutch is OEM / knackered already ! [smilie=tongue.gif]
Ah yes, thanks for clarifying [smilie=gt-happyup.:...only if your clutch is OEM / knackered already ! [smilie=tongue.gif]
Yeah, now the Sports grill is here I like it more and more. So I'm keen to get it bolted on. There's no denying it's an improvement over the OEM 'aquarium' grill (a great quote from a fellow Civinfo'r).Nice !
That's why I don't have heat issues with the FMIC. ;-)
Multi-tasking Farqs ?
Thanks, yeah I should have swapped the grill months ago, but didn't see a need.Looking good Farqs, has taken a good few years off the old gal with the grille, and you'll love the FMIC. ;-)
With the FMIC she seems[\I] to warm up a bit quicker and temps are soon steady at 78/9c. The open grill will come into play during the summer.
No bud, not at all.Have had a couple more drives now and I think the map needs a tweak, she feels a tad rougher at idle/low revs. Did you find this?
I don't get that, either. Once the power comes in when the turbo starts, the delivery is as smooth as a baby's proverbial, climbing the north face of the Eiger.Pulls like a loco when the hammer is down thoThe 2,5k boost kick has evened out over the range.
I found that in my stock map after the FMIC, the turbo was overboosting at around 2300rpm and then overcompensating. Reason is you add bit more air in the system (volume) with the FMIC and it needs couple of more seconds to deliver the boost to the manifold. So ECU sets the desired MAP but it takes a bit longer to deliver so ECU keeps asking for more MAP, and then when it hits it, the second waive comes bit too much and then overcompensate - kills the boost. In my stock graph i had a sharp torque peak because of it.Perhaps its just the turbo coming on boost then. Would be interesting to ride in someone else's, I'm not sure I can make next wkend Donny meet thoMind you, my cars no looker, she's a reet 'battle bus'
I still have the smokey cold start (dammit) so perhaps I'll need that EGR delete Fahad suggested.
Cheers. That big lump-a-alloy isn't going to rattle now.Top man, me likey. ;-)
:congrats:
