Perfect, ThanksI corrected my link in my original post, try it now.
I thought that too bit there seems to be conflicting info online.I thought glowplugs weren't service items? Meant to be lifetime items? But I mean if it helps then maybe I'll give it a go too!
I'd only swap 'em if you have an issue pal. My car ponged of diesel and it seemed to be getting worse.wish I'd got some for them to do in my service. Doh! should improve things Lee![]()
Oh ok mate. No diesel smell with mine, so I'll leave em. 103k mateI'd only swap 'em if you have an issue pal. My car ponged of diesel and it seemed to be getting worse.
How many miles have yours covered?
that is NOT a job I would want to do myself! [smilie=nope.gif]New bush almost pressed home
Haha, I wasn't too keen either but with the right tools it's a doddle.that is NOT a job I would want to do myself! [smilie=nope.gif]
You're a role model to us all Lee! How much power are you running or are you not sure?It's about time I recap'd my recent updates;
- 6kg front springs - MeisterR (from 5kg), damping 10 from soft all round (from 3)
- Moog drop links (were Meyle HD/fat head 44mm, to 34mm approx), front brake block brackets flattened/drilled for drop links to clear
- satnav disk 3.A
- MTEC ATR plain front disks, treated black (were grooved)
- annual service
- front wishbones, front bushes now OEM (were Polyb)
- stainless 'Civic' sill trims
- glow plugs replaced
- rear trailing arm bushes now OEM (were Polyb)
The current mod's list...
Mods:
- Performance
Premier Tuning stage2 EGR-off/delete remap (formerly Celtic Tuning stage1)
FMIC, universal 550mm x 180mm x 65mm
with custom AAS 2 piece stainless swaged pipes
CC single plate clutch/SMF - OEM clutch was slipping under powaaah (occasionally), DMF was vibrating too
Clutch damper bypass- Suspension
:transparent_Meister coilovers, ride height dropped approx 15-20mm
springs, front=6kg, rear=4kg, were (5/5)
Polybush suspension bushes - part#s
all now reverted back to OEM bushes
FRS by Grinspeed
Mitsubishi Evo 9 alloys, 17" 8J ET38, Falken 452 235/40 ZR17 90Y's (came with the alloys)
to fit these you will need: flat seat M12 x 1.5mm wheel nuts + lock nuts, 67.1-64.1mm spigot rings, wheel center caps and a 15mm rear spacer?
also run; 17" EX OEM alloys (keep as spare set), Goodyear Eagle F1 Asymmetric 2's all round, Super-GT spacers, 15/20mm fr/re
drop links, slim head Moog (3yr warranty, replaced Meyle HD links)- Brakes, Calipers
front: :honda: Accord Type :typer: (2.2, '98-'01, #CH1) twin piston (OEM: single piston)
rear: OEM
Disks/Rotors - MTEC
front: :honda: Accord Type :typer:, 300mm dia, 28mm thick (OEM: 283mm dia, 23mm thick), treated (black), plain (non grooved)
rear: OEM 260mm dia, 9mm thick, painted, grooved
Pads - Mintex
Fluid - DOT 5.1
Lines - :hel: FN2/FK2 braided- Styling
:honda: Sports Grill - old/new
:honda: Alloy Sports tank lid/fuel filler cap
3/5 door conversion, exhaust hangers, before/after
Type R dash surround,volt meter now fills the manual headlight adjuster- Electrics
extra 12v/USB outlets in rear of centre console
Curtis earth kit
reversing camera/video in cable
Mr JP's :Aurorab: HID's, LED's; boot light (SMD side lights, white high beams - removed)
Mr JP's :Aurorab: CREE LED front side lights, rear brake lights
Mr JP's :Aurorab: LED's; interior, exterior (bar indicators/rear fog)
Philips X-treme 130% H1 main beam
3rd/high level brake light - full width Knightrider SMD LED strip- Interior
:honda: Drivers Mat Securing Bracket - it now stays put!
Genuine :skunk2: gear knob
Katsock knob warmer + mrsF's custom knob warmer - you can never have too many
Type R dash surround, blue volt meter now fills the manual headlight adjuster
Leather interior (fr/re seats, door cards, arm rest), heated front seats
Footwell lighting kit (dimmable, blue, ignition live)
XCarLink, USB version
Stainless steel 'Civic' sills, front/rear- Misc
:civinfo: sticker!
wanner69 fog protectors - clear
Westfalia detachable towbar/electrics
uprated tailgate gas struts - Mercedes ML W163 1998-2005, 510Nm (from 465Nm)
Short shifter
Satnav DVD# 3.A
Aw fanks man. It's surprising how quickly the mod's soon accrue.You're a role model to us all Lee! How much power are you running or are you not sure?
Any plans for the future?!
Thanks, I hadn't seen those. They look better made than some of the fleabay knock offs. They're pricey tho.
