1 - 20 of 27 Posts
So my 2 day old civic is already giving me a head ake, i brought it with out realising the aircon doesn't work (rookie mistake i know) , so after going through the forum (witch was very helpful) i ordered my self a new relay ! annnnnnd no :( the compressor still doesnt spin :'( my question is if the gas in the system is low will this prevent it from spinning ? , so if i take her for a regas might this sort the issue ? OR does it spin weather its got pressure or not ? , ive not done very well here ! haha , i have checked the fuses and replaced the relay
thanks for reading
i-Vtec
If the compressor doesn’t spin after new relay it will either be low on gas or a knackered compressor. If its been a hot day it may also be that the shim behind the clutch has swollen and needs swapping for a new thinner one too. If I was a betting man Id go with low gas though. You are correct in thinking low gas pressure wont allow the compressor to kick in.
Discussion Starter · #3 ·
ah sweet , looks like ill be grabbing that groupon for a cheap regas and trying that ! thank you for the reply , tbh im still a little embarrassed i didnt check this when i brought the thing !! talk about school boy error
i-Vtec
I just replaced my condenser last week, re-gassed yesterday, I’m hoping that was the issue.
Discussion Starter · #5 ·
i guess for someone who isnt very mechanically minded , (like myself) a condenser swap is hard ?
i-Vtec
Not really. 10mm spanner/socket and a screwdriver to remove the pop studs from the plastic slam panel. Remove the front grill. 4 bolts hold the slam panel cross member in place, just move this over the engine, no need to disconnect the cables. I did cut the plastic from the lower shroud amnd push it out the way to get to the lower AC union but that was as hard as it got. The condensor is only held in by 4 rubbers, 2 top 2 bottom, and the two pipes. Think it took me an hour in total.
Discussion Starter · #7 ·
ah so that is something i could have a crack at :D i take it the compressor is another kettle of fish ?
i-Vtec
Never done one, but Aux belt off, disconnect pipes, unbolt. The Shim replacement was easy enough on it, biggest pain was having to remove the underbelly tray, which you would need to do to replace the compressor.
Just be 100% sure it is out of gas before you start disconnecting pipes, as you could not only get a nasty burn (or whatever the opposite is, as its a refrigerant, so will freeze) if you release the gas, but its also illegal to release the refrigerant gas into the atmosphere
Best bet, is just take it to a specialist to diagnose exaclty what the issue is, as if not you could end up playing "parts darts" with the aircon system
Moderator
Why would you even consider a condenser change without doing leak tests? :eek:
If/when you get it re-gassed, get the operative to put a UV dye in. It will make tracking leaks a piece of p***
Discussion Starter · #11 ·
She's booked in sat for a regas 😊 I'll ask em to stick uv in as well and hopefully will sort it if not ill have to get It in somewhere and cross me fingers it's nowt serious
Discussion Starter · #12 ·
Bad news :(
The regas didnt fix it :mad: the garage did a pressure test ect and they say its not leaking , ive checked all the fuses and relay again and nothing , when i press A/C button the fans on the radiator spin up but the compressor clutch doesn't even twitch :(
i think its goosed
i-Vtec
Ok so I would start with the cheap option. Remove the shim behind the clutch and try again. You need to pull the engine tray to get to it, but its a couple of bolts. Ill link you the how too.
i-Vtec
Discussion Starter · #15 ·
just to make things worse someone told me to disconnect the little sensor thats on the air con line and see if it fires up for a few seconds . and its turned me Pgm-fi light on the dash :( im gonna stop messing lol
Discussion Starter · #17 ·
will i be able to get the clutch apart with a spanner ya think ? i dont have an impact :( if so ill try this next weekend
Had exakt the same problems on my Civic -06 and it was the AC-Compressor that was broken.
Discussion Starter · #20 ·
OK another update fiddling today and managed to get it fired up!!, I gave it abit of a push with a bit of wood and of it went! Span up stone cold air 😜 but when I switched her of and back on again nothing compressor wudnt spin with out me giving it another nudge with me bit of wood? Starting to think take the shim out?
1 - 20 of 27 Posts
