1 - 20 of 39 Posts
On every journey over 20 miles my Deflation Warning Symbol comes on. It takes over most of the screen behind the steering wheel until I recalibrate.
When it first started coming on I exited motorways etc in a panic and checked all my tyres. However in every case my tyres were all at the same correct pressure so now I try to ignore it.
Today after driving 30 motorway miles, then parked for 45 minutes then driving 5 miles on came the deflation warning symbol. Later today after recalibrating the warning came on after just 10 miles. I checked the tyres after driving another 40 miles and all my tyre pressures were exactly the same as when I last checked yesterday. The message can only be removed after recalibrating which can only be done when stationary and the auto in P.
Does anyone else have this problem and been able to fix it? I'm told each wheel has a sensor one of which may be faulty with the fault only showing up because I recalibrated after fitting a new tyre.
Grumpy Old Git ;)
The wife had this issue on her CR-V, and it was resolved with a software update.
However Honda use a crude rotation count method, donut could be a faulty wheel speed sensor.
Unsure if the system had improved any, but does it advise you what tyre has "deflated"?
Thankfully my car actually measure the pressure in each tyre, and highlights the defective wheel, German engineering though.
Sent with the help of Tim Berners-Lee....
Unsure if the system had improved any, but does it advise you what tyre has "deflated"? .
Unfortunately there is no obvious way to know which wheel has the problem. As none of the wheels has a puncture it is only the warning message that says (wrongly) a tyre has deflated.
I had A run over to Manchester today in the CTR , 100 mile round trip and had this come up twice ... not had time to check the pressure yet as only just walked in but for a car with less than 250 mile on the clock..not good :surprise:
Make sure you start the recalibration with the engine off. Don't know why but apparently makes a difference. Had mine come up, tried to initiate while engine running, came back on after about 15 minutes. Second time engine off, seemed to do the trick.
I have the other system on the truck. Actually prefer the rotation count method. You don't have to pay and arm and a leg on a second set if you swap wheels. No need to worry about the tire shop damaging a sensor when fixing or replacing a tire.
Grumpy Old Git ;)
Yes, exactly the same as the wife had on her old CR-V. I thought the may have improved the system my now. But obviously not.
As above, it was resolved with a software update, however it could have just been coincidence. We sold it a few months after.
No issues with the HR-V yet, but it's only got 3k on the clock in 7 months.
She prefers to drive mine when I'm working from home.
I Hate tailgaters!
I'm sure you can deactivate it. Switch it off for a few days then reactivate.
Had fk2 chuck this up around 10 times in a week and then it settled down and never did it again, just check pressures reset a few times and it will sort itself out
My fk2 did the same. I've not had any issues though with the 1.5 sport plus (touch wood).
Make sure you start the recalibration with the engine off. Don't know why but apparently makes a difference. Had mine come up, tried to initiate while engine running, came back on after about 15 minutes. Second time engine off, seemed to do the trick. .
On the Civic the option to calibrate is greyed out until the engine is running (or key is in position 2)
Car is booked in to my dealer for a Software Update.
They want it for a whole day. They say the original specification coded in the software is too small a tyre variation. The software update increases the pressure variation by 300% what it is now.
This fixes what has become a common problem with Civics.
Earth Dreams :)
Had this on the CRV.. but it was actually proven to be right N/S/F tyre was 5 psi less than the others... I check the tyre pressures, oil, screen wash, brake fluid etc etc every week just to be on the safe side..
Anyway, with the CRV - had when I amended the tyre valve issue and knew all the tyre pressures were spot on, I had to do a reset a couple of times to stop it pinging up. All was well after that.
FK8 CTR - not had that problem with that yet..
Correct, start it in position 2 with the engine off. Then turn on engine and drive off.
With the engine running it always came back in my experience.
Any other info on this whole day update? Particularly, GPS accuracy? Keep us updated. Thanks.
Discussion Starter #18
I had the software update done while I waited. It only took an hour from arrival to leaving. So far the deflation warner has not appeared again.
I'm told it will still work but it will not raise the alarm until there is more difference between one tyre and the rest. It seems the garage can choose what parameters it wants to set.
Hi.
Does anyone know how accurate this system should be? When i got the car the warning was on and after inflating a couple of tyres and recalibrating had no more warnings. I checked the tyre pressures a few days ago to find that they were all 6psi down (but no warning). Is this normal?
Hi.
6PSI Down seems a lot, did you fill them when hot?
If the tyres all deflate equally, there will be no warning as it bases the warning on the difference between individual tyres; If one deflates it will warn you, but if they all equally empty, there will be no warning.
1 - 20 of 39 Posts
