As the title suggests. My DVD unit has started failing with "disk reading error". Using a disk cleaner didn't fix it this time around and so I need to replace it.
My car is an 2.2 EX
Product code is: 39540-SMR-E010-M01
My question is. I have found a much newer replacement with the following code from a 2008 FN2.
39540-SMR-E020-M01
Are they interchangeable as lings suggest if you buy from them its the same unit but as the number is different I don't want to make an assumption to find its not compatible with my head unit, aircon and HST as when removed the screen doesn't function.
Thanks in advance
Rastaman
The reason I want this one is because I know its a 2008. I am also interested is its likely to open up for more choices .
