How does anyone know if the front and rear suspensions need to be changed by the dealer?
Are there any creaks/noises someone needs to identify that indicate faulty suspension?
Many thanks,
vtecpower
Assuming what you mean by 'faulty' relates to the various posts on this site, you will be hearing clunks from the suspension when going over bumps. The bizarre thing is that front suspension clunks sound as if they are coming from the rear!
If it is quiet (notwithstanding 'normal bump thump') then you are not experiencing the 'common faults'. Its always possible for infantile failures to occur earlier in aproduct life, but these are rare and different from a manufacturing defect which shows itself as described above.
