I've tried all sorts to figure out the problem with my Headlight Washers. They don't seem to pop out no matter which was i try, fused checked, lights on and follow manual but still nothing. DO you think its the motor gone on the head light washers?
They should work (if fitted of course) when the lights are on and you operate the windscreen washers for a few seconds (you need to make sure that there is enough fluid in the washer bottle as they pop out under pressure.
If that doesn't do it, a trip to the dealers should sort it. Not the time of year to be without them.
Ive had the same problem, the dealer fix is to add more fluid. There are apparanty 2 take off's for fluid the lower one in the bottle is the screen so it works with low levels of fluid. Make sure your fluid level is topped up sorted mine out
The previous generation civic (and the Jazz) both do that.... so when the rear window wash stops working - you know its time to fill the Window Wash Bottle.
(There is normally plenty in reserve for the front screen though!) ;-)
This has been for sometime now and it's getting increasingly frustrating I had a leak in the boot where it runs around the boot the rubber part.
It's also on the rear strut tops?? Where are the common problems at because I can't see anything on the net mk8 civic... Also noticed slight water...
Hello,
Recently my passengers side heated Wing mirror has stopped working, although drivers side is fine.
The electric mirrors move fine on both sides, just seems to be the heated element on that 1 side.
Any advice??
hi guys i have an issue with my car the engine is smoking, smells like burning and there is a weird noise im assuming the car is done but id just like some confirmation lol thank you here is a vid of for refderence.
Hello guys, I have weird exhaust problem. The car is Civic 8th gen 2.2 ctdi 2009. Sometimes the car goes into a mode where the exhaust sound becomes really deep like a racecar, the engine fan turns on, the mileage goes high and it start to smoke a lot. The car has a DPF, but no "DPF regeneration...
