1 - 17 of 17 Posts
Ok, today I looked at my fd2 cams which are going to be installed very soon. The lobes look smooth and in good condition. But on 1 cam in the black part between the lobe there is a something like a line in the black "paint".
What could this be? Is the cam damaged? Probably not. But I want to be sure.
Could this happend during transport?
Or is this normal?
I didn't take a pic as I was certain but now I have doubts.
Reactions: fn 2 awsum
Did it look like this:
There are other marking on them too like " R1" and " R2" etc, these are just marking to distinguish different cams, or did you see something different.
Hope this helps
Discussion Starter · #3 ·
No, it was more something like a scratch.
As long as it was on the "black" bit and not on the Cam lobe or running surfaces on the mounting towers it shouldn't matter I would of thought
Discussion Starter · #5 ·
I looked again, the marks are left and right of "IN" on the cam, from top till bottom. Maybe they were used and sold as new.
Yes, I think the same
Discussion Starter · #7 ·
Bought them from cpl
OP - post a picture of the marks. If they are damaged I'm sure CPL will look after you.
Also the markings such as "R1", R2" etc on the cams aren't unique to the same part numbers. I had three FD2 intake cams infront of me, all of which had different markings. The markings are for casting batches.
what are the part numbers?
i've got a pair myself and the part numbers are from US ACURA RSX
Part numbers here:
FN2
14110-RSP-G00
14120-RSP-G00
FD2
14110-PRC-020
14120-PRC-020
USDM 05-06 dc5 k20z1
14110-PRC-030
14120-PRC-030
JDM k20a ep3 & dc5
14110-PRC-000
14120-PRC-000
USDM dc5 rsx-s DC5
14110-PRB-A00
14120-PRB-A01
'06+ USDM Civic Si k20z3 Fg2 (coupe)
14110-RRB-A00
14120-PRB-A01
'06+ TSX k24a2 CL9
14110-RBB-A00
14120-RBB-000
'04-'05 TSX k24a2 CL7
14110-RBB-000
14120-RBB-000
Discussion Starter · #12 ·
If you look very good you see the "mark" I mean on the pic stoney posted. It is situated on the left of "IN" on the pic. Just above the plastic.
Discussion Starter · #13 ·
Discussion Starter · #15 ·
I know the marks you mean. As if they have been filed. Nothing to worry over. Its normal
Ok, I was just a little bit worried :). But what are these marks then? Now I'm curious.
1 - 17 of 17 Posts
