Cheers chaps got everything fitted took a good 10hours!
FD2 oil pump delete, FD2 cams, New timing chain, RRC Mani & thermal gasket for Mani & TB plus valve clearances set
Everything torqued up correctly
Sounds really meaty and strong no vtec yet you wern't kidding about the remap!
Deffo needs it, acceleration pedal is dull, shakes and revs sometimes bounce on idle and seems rough like it's fighting to stay alive
Booked in Friday for mapping, will this require the 410cc RDX Injectors or uprated fuel rail?
Fuel rail not required. Might get away with stock injectors but dyno tune will tell if you require 410 or not.
Im not actually sure if im on oem or 410cc injectors although do think on 330cc. I run increased fuel pressure though and aftermarket fuel pump. My mugen rail was fitted by prev owner just because looked good !
I'm still on OEM injectors but I'm only on standard cams. As vti said, difficult to say whether you'll need bigger ones until it's mapped but they usually become the limiting factor when cams come onto play.
Well at least its with peps who know what they are doing. It will get their, I suppose its best to find these issues out now and have it bang on when it matters.
Who's mapping it ? I had occasional mis fire few years ago so just gave car to tdi north.
Turned out to be coil pack so they put new 1 in.
While car was on dyno being tested they found out 02 sensor was on way out so new 1 put in from honda. Not cheap though as about £250 for oem sensor alone. Glad they spotted it though as couldnt tell driving it.
TDI South , they raised concerns about the car missing but said it was intermittent and to book back in as it hit 5.30. I took it a mile up the road and it was really really bad felt like it was choking, jumping, going to stall etc
Basically totally undriveable
Needles to say I took it straight back and it will be looked at Tomo for fault finding
Needles to say I took it straight back and it will be looked at Timothy for fault finding
I hope you get it sorted, Im sure these guys know what they are doing and will get to the bottom of it. Did they lend you a car to get home. Did they mention what it might be.
