1 - 2 of 2 Posts
Hi Guys!
My bros' fd2 is due for its 3rd service. Due to the low mileage of it (16k), he intends to have; oil changed, new brake pads fitted...but is there anything else he should consider with the mileage being considerably low? Also is there a service schedule he should follow?
Advice is much appreciated ;)
I do gearbox oil every 10K or 12 months as mine does tend to get a beating :) You could check valve clearances but they should be OK for at least the first 20K, esp on standard cams. Check the air filter too (I assume you're changing oil filter). Other than that, just the usual checks to see if anything else needs attention
1 - 2 of 2 Posts
