1 - 20 of 29 Posts
So I went shopping and got a little carried away and came home with a Pioneer AVH-X3500DAB.
One of these:
http://bit.ly/HyAmh8
Don't know why I went for the DAB model but it seemed like a good idea at the time :)
So who's got DAB and where have you fitted your dab aerial ? The guy in the shop advisedly where to fit it but I'm just seeing what others have done to see what works best :)
Good thinking pal :)
Well I'll tell you how the guy in the shop advised me to fit it first too. He said:
Take off the a pillar trim on the passenger side and put it half way up the window. He says the black piece that's an L shape is a sticker with a copper base which needs to be earthed to metal so to stick the little black box next to the a pillar with the L shaped piece sticking on the metal of the a pillar so when the a pillar trim is put back on all you can see is the little black box stuck to the windscreen.
I hope that kind of makes sense lol
Do you have a glass roof? I would be tempted to put it up there, where the bar runs across.
You will also have the thin strip stuck to the window too, as shown below. (Stolen from Kenwood website)
You should be able to attach some wire to the black sticker and run that to a convenient ground point.
Depends how much having that black box and little wire shown on the windscreen would annoy you, the A pillar suggestion is perfectly fine.
Yes mate I do have a glass roof and that's a cracking suggestion. Not sure if the signal strength may suffer a bit though. I'll do some more internet searching on that as I like that idea :)
Sunday morning bump... Some of you guys must have bought and fitted a dab radio. Or are they pants and I've messed up buying one ?? Lol
I don't think you really have many choices for fitting it, either at the top of the windscreen if you can find a ground point, on the glass roof, or by the A pillar as you mentioned.
I would assume that most people who upgrade their headunit would have their music on a USB drive or equivalent, rather than listening to the radio.
I have dab fitted as standard on my new ex, whilst I haven't played around too much I have noticed the sound quality is far superior and there is a greater choice of stations
Finally bought my double bin... Now a question about DAB ??
I had he exact same headunit as you installed in my Civic.
The DAB was great. As mentioned so much more availability of stations, including some that are only available on DAB. I particularly loved the 'Absolute 90's' station. There was a 70's, 80's, 00's available too.
Quality of sound was superior to standard FM/AM also. Clearer. Like comparing CD/IPOD to a tape.
A good feature of the X3500DAB I also enjoyed was when you are listening to a DAB station and lose signal it automatically switches to the FM broadcast if DAB signal is lost or weak and back again once the DAB signal improves again.
I found in most places in the UK. DAB coverage to be pretty good. Only really found the signal being hit and miss when I went north of Central Scotland but even then it wasn't drastically poor.
It's also good as quite a few local stations are available nationwide on DAB. I was able to listen to BBC Scotland all over the UK and Clyde 1 (only available in West Central Scotland on FM) all over Scotland meaning when away with work I was able to listen to Scottish football etc.
That's great to hear a good review from someone who had the same unit mate. Really appreciate that. Where did you have your dab aerial mounted ?
I had mine on the top of the windscreen directly behind the rear view mirror. The black matrix hid the copper part and the mirror itself hid the black box from view so nothing was obviously on view from inside or outside the car.
Discussion Starter #12
This seems to be the best place to put it but according to my instructions the black sticker part with the copper base needs to go to metal to be earthed ? Or does that not really matter ?
I never earthed mine and it worked fine? Is it the official Pioneer DAB Aerial. I had the proper Pioneer one and it never mentioned earthing anything.
The guy at the shop said they use the Alpine dab aerial as they've found they work better but are the same design. It was him who told me to mount it by the a pillar and stick the black onto the metal behind the pillar.
Did you so your yourself ? If so how do I remove the a pillar ? I don't want just go pulling at it because of the airbag lol
I simply tucked the cable in all the way around the windscreen. Didn't need to remove anything.
Lol I'm obviously over complicating things. Never thought of that :I lol
As mentioned above, no need to actually remove anything if you don't need to ground the aerial.
You can just push the wire up and round, I've done this with the wire for my dash camera, which I will be posting pictures of in my thread today.
Nice looking system, are you connecting an iphone to the system? Don't suppose you have had a play with the screen mirroring (navigation in particular)? Would be interested to hear your opinions :p
1 - 20 of 29 Posts
