1 - 14 of 14 Posts
hi guys, i'm opening this thread because i don't understands why i'm not able to fit perfeclty the panel of my autoradio , as you can see on the pictures on the right side ( europeen model ) there is a little space, i already made a cut on the dashboard inside, it helped a lot but now it's still unperfect and i don't understand why
as you can see here it's perfect when i make a pressure with my fingers
i noticed on this youtube video : [ame]https://youtu.be/QKHGlKusj9E?t=619[/ame]
the guy have the same problem as me the right side have a little space , so if someone got the same problem as me and could help me i will be more than reconized more than 3 hours i'm searching how to fit the panel perfectly , btw as i said i made a cut on the dashboard of the civic and it seems much better than without cutting, but now i guess i cuted almost everything possible so i don't understand .
when i put the panel without the autoradio it's fitting good .
hope you could help me guys thanks ! for the rest everything is okay and the double din works perfectly
I noticed this with myne it's the double din unit plastic I think it's a bad batch I cutted away everything and still just slightly sits proud!
i noticed on this youtube video : https://youtu.be/QKHGlKusj9E?t=619
Sent from my Robin using Tapatalk
no i don't think it' s the panel , because i bought 3 panels ;'( and got the same problem on the 3 it's impossible , btw my brother have the same civic and a mechanician put the panel perfectly
and the panels come both from aliexpress , same seller etc.
Arh so I got it flush then?
You sure all the cables behind have been pulled down out the way so theres enough room at the back for the ddin to sit flush?
Most important thing:
Where can i buy it and where can i find a 2din radio that can work with the steering wheel controls?! :grin2:
Olà :)
i used this patch and works perfectly : https://www.ebay.fr/itm/CTSHO002-Steering-Wheel-Stalk-Control-Adaptor-FREE-PATCH-For-HONDA-Civic-2006/270872820242?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
he comes with everything you need + he work with all the brands mostly.
Contact the seller and check if it's compatible with your autoradio if you have any question ask them
Alright after 4 hours of research and everything removed ... I found a solution of my problem ,
so the solution i found for my problem maybe it's not the best option but it's working ... so if it can help someone, i added a screw ( or another thing) to make the wholes smaler and it force the panel to stay correctly ( if you don't use any screw or other thing it stay at the top of the whole and that's why we got the problem. and now using a screw it fit perfectly .
As you can see on my pictures
Thats where I got myne from for my android stereo it's that one
Olà :)
i used this patch and works perfectly : https://www.ebay.fr/itm/CTSHO002-Steering-Wheel-Stalk-Control-Adaptor-FREE-PATCH-For-HONDA-Civic-2006/270872820242?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
What size is the screw please M3,M4?
aproxymatively the same size as the 3 ones you have at the top to fix the panel on the dashboard ( let's say m4) and you could use just 1 srew in the middle whole it works
post a pic before and after if it worked for you ;) thanks mate
1 - 14 of 14 Posts
