Have you had any FK2's in for geometry? How adjustable is the standard set-up if so?
We've done a couple now.
As standard, front toe is the only thing adjustable.
It has a revo-style front suspension setup (like Focus RS/Megane sport) so there is no way of fitting camber bolts like the older models).
Having said that, the alignment has been very good on them from the factory.
We have all the data and recommended settings so can check and set it if needed.
Hope this helps,
Rich
Thanks for the reply, will there be any likely development on this or is unlikely to change?
I wouldn't have thought it would change too much. Maybe adjustable top mounts would be the way to go, but I don't think there is anything available at the moment.
Rich
