Hi chaps
newbie gen8 06 deisel ex owner, i think i might have an intermittant electics problem hoping *** have some ideas whats going on...
Turn the key and immediately the dash display will start flickering on off on off all lights bells and whistles and the wipers will wipe. When it stops i press the start button and it starts ok but the Check Airbag (or SRS cant remember) System warning comes up and stays on until i turned the car off. I removed the key and re-inserted and it its all systems go and no sign of any airbag warning!
Its not the first time the lights have flashed on turn of key, but is first time for airbag warning!
I have recently re-plugged in an unplugged HFT module which seems to only work when it wants to...could it be this? I do intend to remove it and poss fix it.
Other symtoms are intermittant flickering left HID light.
Also car has been sat on drive for 2 months before being used now..battery was waining a little but now has 2 weeks normal daily use so should be fully charged and operating normally.
And lastly i have what i beleive is a dimmer than usual satnav display, and it does appear to get brighter when warm. Again its another issue i was going read-up and find a fix for.
I suppose im asking is any or all of this related at all? or is all these just little small isolated issues?
Looking for any suggestions or ideas what could be going on or wot tests i could do?
Thankyou in advance
Jakey
hi jakey
the first thing I would do is get the battery properly load tested and check the alternator output is good
also check the battery earthing wires are good as they are a bad design and can cause all sorts of electrical problems
could also be a problem with the ignition switch
the airbag system will probably be picking up a low voltage that will clear itself on next start up when it is happy with the voltage
hi jakey
Thats perfect, thankyou! its a start and I'll get cracking with these checks and tests and report back.
if it is a problem with the earth cables there is a member on the forum that sells realy good uprated kits
Ok thanks. By uprated i guess you mean better than Honda-designed kits??
This could be a looking like a job for an auto-electrician if i dont find anything obvious!
Clutch pedal guru
Make sure the battery is working properly first before spending ANY sort of money on earthing kits.
Reactions: Jakey and p7jox
hi there the earth lead that usualy causes the problems is the one fron battery to the innerwing/chasis rail If you un bolt the lead at the innerwing and clean the ring terminal with some sand paper it usualy does the trick also chech for signs of corosion whare it crimps to the cable
as for the battery/alternator most good garages/fast fits will check these over free of charge just make shure that they do a proper load test and not just test with a volt meter
Perfect, thankyou both much appreciated. I have somewhere to start and will update
