Hi all. Here is another handling problem which I can’t seem to figure. Basically when driving the car this is how the car feels. It feels a little flouty and unstable. Small input to the steering is not Persis or accurate. You feel like you need to adjust the amount of turn all the time. Throwing the car into the turn and pushing right up to the braking pint of grip and the car turns in fine and rids flat. I dose feel like it wants to over steer thou the harder you corner.
There are a few strange sounds. When pulling off or coming to a stop or hitting a bump you have a clicking sound like tapping plastic.
When going over very rough uneven ground there is a very fast rattle like something is under tension and bouncing.
I have changed on the car but not really help
Heavy duty drop links
ARB bushes
Rear trailing arm bushes
The car has been to Honda and had the sub frame cleaned and greases (not difference)
And another garage who found nothing shocks seems to be fine.
Would you be able to tell if the shock mounts where knackered without taking the shocks off the car? As I starting to think it is that but don’t know the tell tell signs of knackered top mounts or bearings/bush.
If anyone has any ideas I am all ears.
opcorn2:
ARB bushes
