1 - 11 of 11 Posts
I've just bought a new FM transmitter to plug my IPod Touch into.
The transmitter works absolutely fine, but I have a problem with the Honda Radio!
It has an automatic tuner feature so that whenever you tune to a blank FM wave after 30 secs or so it retunes it to another radio station that isn't blank. Arggghhhhh!! :mad:
I've trawled through the manual and can't seem to find a way of turning the feature off.
Does anyone have any idea how to stop it from doing this?
Good luck with that, what about finding a station further away, tune in to this station, and store it - then drive away from that station, then you may be able to use that frequency for your Ipod Fm Transmitter - I'm lucky enough to have USB , I create mixes using High quality MP3, and don't bother with the Iphone.
Discussion Starter · #5 ·
Thanks for the messages. I've tried storing the frequency on a preset channel, but it still tries to navigate to a stronger signal. I'm at a loose end!
How is it that other people manage to use their transmitters?
I picked up a transmitter today a belkin tunecast (even displays track names on the RDS display) anyway you need to preset the FM transmitter first then play some audio throught it. Then use the honda stereo to scan for that station it should then stop on the channel and just save it as a preset.
You need to fire up the Transmitter first, then the Radio should find the frequency like a normal FM station say 87.7 - this worked in my old Peugot 306, plus use a memory stick in the MP3 Players that plug in the Cigar lighter - even the Socket in the Boot of the Civic (you won't even see it)
1 - 11 of 11 Posts
