Hi if I fit the balance shaft delete kit , does this have any down sides to it and what should I expect it to do once fitted
Downside probably is going to be increased vibration due to removing balance shafts, but it will settle after few hundred miles or at least people claiming that.
It will reduce internal drug on the engine which will free up few bhp, higher pressure from fd2 pump to lubricate the head, it will be more eager to rev and will rev higher safer.
Plenty of info on this forum if you use the search.
I'll do mine in a few month time and will go to Honda HQ.
Takes an extra litre of oil come service time.
Also allows you to fit one of these beauties if you're serious about track days,
314609
Reactions: saif.mansour
