Looking at buying some new discs and pads at euro car parts for my FN2 - got rear discs, and front/rear pads in my basket but can't find front discs!!
If I look at EP3 front discs there is loads on there, but non for FN2. Aren't EP3 & FN2 brakes the same, and if so which ones am I getting? (Ideally want the Brembos) To further complicate the matter there are 3 different Brembo discs for the front :scream1:
Any help would be much appreciated.
Thanks in advance.
Thanks Anthropolyte that helps a lot - I can now get some discs for a decent price :grin2:
Still confused though - from what I can see there are these options (all vented & plain), and the differences are in the dimensions:
Brembo Brake Disc (Front)Product Code: 10460035A
Brake Disc Thickness [mm]23,0
Brake Disc TypeVented
Centering Diameter [mm]64
Diameter [mm]260
Height [mm]44,5
Hole Arrangement / Number04/08
Minimum Thickness [mm]21
Pitch Circle Ø [mm]100
Weight [kg]5,42
Date To 01/2004
Fitting Position Front
I think we can rule this first one out... wrong hole arrangement?
Brembo Brake Disc (Front Axle)Product Code: 10460039A
Brake Disc Thickness [mm]25,0
Diameter [mm]300
Height [mm]47,2
Hole Arrangement / Number05/09
Minimum Thickness [mm]23
Pitch Circle Ø [mm]114,3
Weight [kg]6,84
Fitting Position Front Axle
Brembo Brake Disc (Front)Product Code: 10460181A
Centering Diameter [mm]64,2
Diameter [mm]282
Height [mm]47,3
Weight [kg]6,1
Date From 01/2004
I don't want to end up with some that won't fit, but I'm struggling to understand the differences:confused:
Marty says BWAAAHHH!!!
250bhp.... finally :)
Can also confirm they're 300 x 25 so the second one :thumbsup:
