1 - 20 of 28 Posts
Hi guys,
about a week ago the nearside part of my Invidia cat-back started to make a knocking noise against something under the car. after a bit of 'googling' i found some info saying that ford escort ones are a good fit, so i ordered some new mounts off ebay - 2 Exhaust hangers for Ford Escort 1.6 55 Van 1980-90 FDR4 PSM54C FDR35 PSM62C | eBay
has anyone used these particular ones before and do they stop the (rather annoying) knocking noise?..
cars in for MOT a week tomorrow and for this to get sorted, as well as a small 'blow' from the exhaust...
Hi guys,
Quite a few folk in here have fitted these - seems to do the trick just fine
Reactions: -kev-
totally forgot about this thread - my bad :eek:
new mounts have been on over a week now, no knock at all :)
regrets his username
Little bump,
Just received my single exit exhaust and want some firmer mounts, so just wondering if these are the correct ones in the link still and how many would I need (also open to other ideas)
aka Colin
get some powerflex exh011 universal mounts pal, you only really need the 2 at the rear. they are so much better than oem honda jobbies.
My toda is doing the same is it just the 2 I need?
My Toda (full system) seems to be a little rattly on pull-away, not sure if its catching a heat shield or something? was wondering if it was the exhaust mounts? (I have the poly bush kit for the engine mounts) Am I right in thinking you need 5 mounts to sort the whole exhaust?
No because some of the mounts at the back axle are different .
The power flex can only be used in three places .
First bend after the cat
2x rear hangers
I ordered a few of these, the holes were too small, so I drilled them to so that they could fit. now 2 have burst. Did anyone else need to drill theirs?
250bhp.... finally :)
I have an Invidia dual exit 3" system and found its the exhaust tips rattling against the inside of those triangles in the bumper, Grinpseed fitted a pair of those powerflex mounts mentioned above and its helped.
1 - 20 of 28 Posts
