Finally fitted my FN2 grill. Not a hard job but took an hour and a half! Things kept going wrong, but regardless it's on now.
How can I get the "Type R" badge off? I was thinking maybe a hairdryer? Will that work?
I want to keep the red badge and eventually plan on getting colour coded.
The Type R badge should be held on with 3 nuts....they aren't threaded nuts, they are pushed onto 3 pins of the badge which go through the grill and keep it in place (don't know the specific name.....sorry!). These will now be an absolute pain to take off with the grill on the car.
The back of the badge also has 2 sticky pads (well mine did, and I only put it on a few weeks ago). Get some fishing wire and run it behind the badge and it will unstick it. And then use bug & tar remover and polish to remove the left over residue
The Dugs Baws
Should have took it off before fitting mate.
It should have 3 pins that have push on clips on the back also double sided tape.
Then again it might be glued on.
Could try a hair dryer and a bit of pulling.
Looks good though!
I should have said in my previous post, that using a hairdryer to soften up the glue will also work. I just don't have the luxury of that seeing as my car lives in an underground apartment carpark :(!
Thanks for help. The reason why I didn't take it off prior to fitting was because it's simply glued on. I've peeled it off now, but has left glue residue.
Bye Bye Type R
IPA should remove all the glue
