Hi there!
When I’m driving normally (tops 5k), the gear shifts are smooth, no problem, but when in high revs, ~6k+ in VTEC, i have to use quite a bit of force to shift through all gears, it doesn’t seem right, also there is no grinding. I revved in 1st to check If the car creeps forward but it doesnt move at all. 1st and reverse from a stop are smooth as well.
What could be the problem? Synchros? Clutch?
Also got some MTF3 ready because I have no idea when the fluid was last changed so that will be done soon, the car has around 200k Km atm. 2007 model.
Change the MTF and then see if it improves.
