I also have a E90 M3 DCT gearbox with an adapter kit. The setup will run a 2.2 CDTI dual mass flyweel modified to fit the DCT. I will run a Mx5 LSD for now because it bolts straight onto the rear subframe and has a lower final drive. I just need a custom prop shaft and driveshafts. If the mazda diff fails I will look at getting an e90 rear subframe cut the diff mounts from that and weld it to the rx8 rear subframe as they are almost identical.
The turbo I have is a pulsar GTX 3076R with a tial 0.82AR exhaust housing.
And this is the goal for me, to have a similar install to the picture below:
I know it isn't a civic build, I don't really use any other forum, so thought it might be fun to bring something different to the group.
