Hello
Has anyone else has the problem of the seal on all rear lights going green and generally looking S**T?
am I able to strip and reseal them?
any help would be appreciated as this is driving me mad
thanks
JollyBoy
Happened on mine too. Honda dealership said it's normal but isn't something you can sort easily. Not sure if that's true or not.
It's actually not the seal. There's a gap between the two layers of plastic that fills up with water and gradually develops mould/moss. Easiest way to sort it is to remove the clusters, grab a toothbrush, a syringe and a solution of bleach and water, squirt the solution through the gap and give it a good scrub. I also used a very thin bottle brush (one for test tubes) to get to every bit. Once done, it should look clear and stay that way for a while.
This and pressure washer from a distance
