All on order!
Rotrex shaft drive kit 30-94
Fabmotion custom downpipe
Invidia Q300 V2 cat back!
😁😁😁😁😁 she’s worth it!
Done cheers didn’t spot thatMight be a good idea if you can blur out your address in the photos
Hopefully fun without ruining the car all together 😂Bet you can't bloody wait, it's going to be a beast.
It will be mrs mode for when she’s in the car I recon.It is, I have eco mode on mine, but only using when in a mood for just cruising(not often).
Oh I’ve looked into it in detail mate, I’ve got the whole kit with the load mass vinyl and closed cell foam already in my amazon basket.Mine is n/a ecutek tuned, standard lsd box.
Consider sound deadening sheets - it worked in my case(I think I’m getting older).
Yeah that’s the bottom of the 3 layers I’m planning on doing too 👍I've used this.
Silent Coat 30 x Tiles (187x265mm) Car Sound Deadening/Proofing Pack : Amazon.co.uk: Automotive
Buy Silent Coat 30 x Tiles (187x265mm) Car Sound Deadening/Proofing Pack at Amazon UK. Free delivery on eligible orders.www.amazon.co.uk
I've thought of this just for use for communting.It will be mrs mode for when she’s in the car I recon.
question have you had the longer 6th gear added? I fancy that to keep cruise volume down
They recon a 10% fuel saving at national speed limit, being lower revs, and less noise.I've thought of this just for use for communting.
Sounds a pretty appealing mod. The gear is a couple hundred quid then whatever it would cost to replace it so it’s not bank shattering if done at the same time as a clutch or synchros etc hmmI'm more looking at the idea that I currently get 40mpg with the stock gear, and I figured being able to drop it from 3k rpm to about 2,500 would help gain another 5 or so mpg. Nice thing being of course that the other 5 gears are the same still, so it's still a Type R, just with a bit more of a GT capability for my long drives.
