Hello.
My brother has got some problems with his type R (2008).
Let's introduce the mods first:
- catalic converter and lambda sensor removed
- miltek catback
- cai cpl + k&n air filter
- hondata flash pro
+ few other not related to the problem upgrades
He had it serviced recently by a local mechanic and now engine is locked out in emergency mode. Vtec doesn't kick in and when it supposed to engage engine is getting noisy with no extra power. It started happening 60 miles after having it serviced. After connecting it to the computer he said that vtec works properly but the oil temperature according to the sensor is -40 degree! During the service he left the radio on and the battery died. He connected the cable to fire up the engine. Later computer showed that some errors with changing cams location. After erasing errors they haven't appeared again but car is still in emergency mode and temp. still -40. He is using Motul xcess 5w40. Any suggestions?
Second problem is with breaks. Discs and pads have been upgraded half of a year ago but previous owner was using motul rbf600. Breaks were rubbish on cold breaking liquid so it has been decided to replace it with motul dot 5.1. Now the rear right wheel is breaking and computer throwing error with breaking sensor. On the dashboard vse and engine check lights are on.
Please help if you have any ideas.
Thank you for your help
- miltek catback
- hondata flash pro
