1 - 11 of 11 Posts
Cars started making a creaking noise when turning steering wheel and its coming from front left, any ideas guys??
Yorkshire Jedi
I had something similar and it turned out to be a broken spring, hopefully not in your case.
I found this morning my steering was heavier probably due to drop in temperature.
When in parked if I turn the wheel all the way to the left it lifts the left side of the car on the front, is that normal?
regrets his username
subframe loose?? it's a common fault and is sorted under warranty, mine would creak like mad when stationary and turning full lock and the subframe was quite loose not done it since it was tightened
Honda nut
my subframe was loose and tightend but the car still creaks when I turn the wheel drivers side ,Ive checked the springs ,changed the arb bushes ,tommorrow im changing the drop links < if it still does it after that I give up .My car creaks like an old floor board
I had the same issue when turning to the left. Honda couldn't find what problem was do replaced steering rack under warrenty no more creaks
I''ve heard a sort of creak/knock when turning sometimes from the passenger side. It's only done it this last week or so. I remember reading a thread regarding removing a bolt from the suspension and applying grease between the joint as its a common fault. Can't remember which bolt it is though?
Hmmmm depends, if its the sub frame then I'd say yes it would be done on warranty (they only pack it with grease and tighten it up) I had my local backstreet garage look at mine, the thing with honda is you have the risk of not being the sub frame and then they hit you with a large labour bill and your talking £100 + an hour, I've just had a service done supplied my own stuff and was charged £180 labour
Fourthdisciple.. Did you manage to find the problem?
Reactions: Dan_CW
1 - 11 of 11 Posts
