1 - 2 of 2 Posts
My engine valve cover paint is coming off and because we don't have many if the FN2s over here there is no way to swap it on the spot for direct painted replacement, due to that I'm thinking that I will just buy k20 cover from ebay and let it repaint, then they can be swapped(no outage on my car :) )
Now the tricky part, are all K20 valve cover compatible or the K20Z4 valve is different from the older ones? Thank you for your wisdom.
The z4 has clip mounts on a right hand (looking into the bay) Other than that, the same. It is a pain in the ass to get on without scratching. You can do it yourself in a day if you're ballsy enough to try it.
1 - 2 of 2 Posts
