1 - 12 of 12 Posts
Hi there, I am looking for new pads and could use some advice. Need some more stoping power. My car is my daily so need these to be effective at low temperature. I do not use my car for track days. Ideally I would like to go under 100£ for 2 pads. Thanks
Sent from my SM-G955F using Tapatalk
A wizard is never late...
project mu ns400's are great from cold and only get better with more heat, ds2500's that i had before are nowhere near as good cold or hot.
i found the ns400s good but the ds2500 even better.
i found the ds2500s to be awful when cold and only good when red hot, whereas the ns400s are good cold and pull my face off when hot.
i really liked them. low dust also but they couldn't take the heat and cracked.
Change the fluid, bleed the brakes and see if that helps first.
Sent from my SM-N910F using Tapatalk
I am puting new braided lines and new fluid but also want to change the front pads as I am sure those are rubbish cheap pads
I found that DS2500s created tons of dust and now run Brembo pads on the front. They seem fine for road use.
The D is for Dave
Have EBC Yellowstuff pads fallen out of favour?
What is the difference between yellowstuf and for example red or blackstuff. This is confusing as hell :)
The D is for Dave
Basically, with EBC pads:
  • Blackstuff = OEM equivalent. Will fade when hot.
  • Greenstuff = OEM but with reduced brake dust. Will fade when hot.
  • Yellowstuff = Performance/fast road pad. Good from cold, gets better when warmed up.
  • Redstuff = Track. Needs to be hot to perform.
That's a very brief summary but should give you the general idea.
1 - 12 of 12 Posts
