Hi.
After tinting my driver/passenger windows they just won't operate proberly anymore when sliding windows down. They can't come up again! Is there an mechanism that can be ajusted inside the doors, so that it can lift the windows again?
The other windows works without any problems!
Thanks.
Thanks wheelchair, I'll give it a try.
Looks rather complicated. If it doesn't work I'll contact my Honda dealer for a solution.
I had this with my drivers front window only, called the AA & the guy managed to get it to go up temporarily until I could take it to the dealers.
Took it to the dealers and they replaced & adjusted the mechanism.
You need to remove the door trim to do it but I'm not sure what they did exactly
I wonder if they might consider the tints to be causing extra friction and may charge for the adjustment ?
