Hi all,
New to this forum. Ihave just moved up to a 2006 civic 1.8 se, from my old 2003 civic 1.4 se. Love the new car.
Was wondering if any one else has had a problem with the wipers not parking in the correct place (off the screen at the bottom), mine intermitently sit up the screen about 2 or 3 inches.
Was wondering if this was a design of the new Civic or if i have a fault with mine.
At the "up" position where the arm stop and go back, they should be parallel to the A pillar. At the bottom of the screen they should be horizontal. The drivers side should be a bit higher up. If I recall correctly it is ~3" from the bottom of the window.
If they have slipped and are not correclty aligned, simply loosen the nut that holds the arm in place and adjust. Tighten the nut.
